Dnes dorazil vzduchovy filtr Mann. Made in Korea
Co vy na to panove?
http://smarty-trend.com/hyundai-elantra ... -unit.html
8 inches, capacitive multi-touch screen;
HD 1024*600px LCD resolution;
Android 6.0.1 (Marshmallow);
1.6GHz Allwinner R16 (Quad-core) processor;
1Gb (Samsung DDR3) RAM;
16Gb, expansible through SD card;
GPS / Glonass positioning system, external antenna is included;
FM / AM radio with RDS and memory for 36 radio stations, high sensitivity NXP TEF6686 FM module;
Hi-Fi sound processor, 4 x 50W sound amplifier MOSFET TDA 7850 class AB ;
Equalizer: Bass / Middle / Treble, Loud. Cutoff frequency: BassF / MiddleF / TrebleF. Separate volume control for loud speaker (subwoofer);
On-board WI-FI, Hotspot mode (access point for other Wi-Fi devices);
3G / 4G Internet is supported through an external USB modem (isn't included);
Bluetooth HandsFree. Phonebook copy function and phonebook search. Separate volume control. A2DP music playback;
TMPS (tire-monitoring pressure system) and OBD2 adapters, connection through Bluetooth;
Steering wheel buttons, supporting 3 programmable functions for one button (short / long / repeat press);
RGB front panel buttons backlight, every color can be adjusted;
Faceplate buttons function can be changed, 3 programmable functions for one button (the same as steering wheel buttons);
Backup camera, supporting every rear cameras (some models support original factory cameras, dynamic lines and park assistance system);
Front parking camera supporting through the "FCAM" or "AUX Video In" port connection;
Standby Mode (10, 30, 60 minutes), the unit will be switched on for 1 second;
Android cold boot time for 20-25 seconds;
Supporting of USB Flash, SD Card (up to 64 Gb) and hard drives (up to 1 Tb);
Supported video formats: RMVB, MKV, MOV, WMV, AVI, MPG, TS with 1080P, H.264, etc.;
Supported audio formats: MP3, WMA, WAV, OGG, FLAC, etc.;
Support Full HD 1080p video playback;
Video output - RCA Female (NTSC, PAL);
External amplifier supporting, 4 channel (Left / Right Front + Left / Right Rear), RCA Female connectors;
External loud speaker (subwoofer) supporting, RCA Female connector, separated sound level in the EQ settings;
Dynamically changing the volume depends on the vehicle speed, 3 modes: low / medium / strong;
Navigation voice prompts. You can choose speakers for voice navigation: front or all;
Microphones, there are two kinds: on-board and external. You can use handsfree function and Android voice programs (Google Voice search, Skype, voice control, etc.);
Video inputs: 1 x rear view camera (RCA Female connection), 1 x AUX In (RCA Female connection), some models have 1 x Front CAM input (RCA Female connection);
AUX Audio input, some models support factory AUX input;
USB / SD card port, 2 x USB ports, some models support factory USB;
Set up your car logo or custom logo;
Warranty 12 months.
- hyundai-elantra-2011-2016-android-car-stereo-navigation-in-dash-head-unit.jpg (28.84 KiB) Zobrazeno 662 x
Jdeš do toho?
Bývalá auta:
Renault Clio I 1.2 40kW 1995
Škoda 100 L 1974
Bývalá auta:
Škoda 100 L 1974
Mně osobně se to rádio nelíbí. Je to ale Alfova věc.
Jen mne to přišlo zajímavé, ale osobně do toho asi nepůjdu
Taky jsem nad podobnou věcí před časem uvažoval. Ale za prví se mi nechtělo nechat kuchat do palubky, navíc to origo rádio tam vypadá pěkně a i pěkně hraje (na originální rádio překvapivě hezky). A na to, že si nakonec pustim jen mp3, na to mi to origo stačí. Navíc u tohoto androidu hrozí vyšší míra poruch, může se to začít sekat, přestat fungovat dotyk atak. To u normál rádia nehrozí
Vim, že to nabízela i jedna firma v Českých Budějovicích a i s výměnou to vyšlo na cca 15 tisíc. A tolik času v autě zase netrávim, radši si koupim za 15 tisíc kvalitní rádio domů
Peugeot 306 r.v. 1996
VW Golf I r.v. 1979
VW Golf I r.v. 1979
Take nezaujalo a za ty penize bych si dovedl predstavit neco jineho.Axel.Foley píše:Mně osobně se to rádio nelíbí. Je to ale Alfova věc.
odeslano z telefonu
Ono to vyzerá pekne.
No auto to nezlepší prakticky o nič.Teda aspoň pokiaľ mám auto na to ,na čo je určené
Najeto rovnych 37 000
Ja dnes za desať.
Takřka po 4 letech zajeté auto...dobře tyAlf6 píše:Najeto rovnych 37 000
6,9l/100km
Aktuálně 50000 km
6,9l/100km
Aktuálně 50000 km
Někdy to přijít muselo
Alfe,v čom je rozdiel medzi 1,6 CVVT v i30 a motorom v Elantre?
Teda okrem naladenia výkonu.
Do 27.000 mi chybí necelých 100 km... po 9ti měsících...petzl62 píše:Takřka po 4 letech zajeté auto...dobře tyAlf6 píše:Najeto rovnych 37 000![]()
Uz na pohled podle oznaceni je jasne, ze CVVT ma casovani ventilu na strane sani. Moje Ela ma oznaceni D-CVVT- tedy dvojite casovani ventilu jak na strani sani, tak má i vyfukove ventily. Jedna se vlastne o takove vnitrni EGR. Vyhoda toho D-CVVT je ta, ze sani udrzuje ciste, jelikož si spaliny cucne do motoru prez vyfukove ventily. Kdo pouziva kvalitni olej a nebo meni v rozumných( skracenych) intervalech, tak se karbonu bat nemusi. Z toho plyne i nevyhoda C-VVT.idam.i píše:Alfe,v čom je rozdiel medzi 1,6 CVVT v i30 a motorom v Elantre?<br abp="823">Teda okrem naladenia výkonu.
Moje Ela má kodove oznaceni motoru 1.6 Gamma II MPi G4FG.
I30 MPI, 1,6 ma kodove oznaceni motoru G4FC. První verze - ma 122 koni a druha ta nejnovejsi pouziva také systém D-CVVT(narozdil od te první) a vykon stoupl na 128 koni.
Nevim jak je to u i30, ale moje Ela je cela delana v Ulsanu. Jestli se do i30 vyrabi motory v CR netusim.
Kazdopadne jsem rad za motor jaky mame..to znamena bez zbytečných kurvitek .
