98 Hyundai Santamo 2.0 G4CP-DOHC 102 kw life with it
Napsal: 16 pro 2010, 20:04
http://i68.photobucket.com/albums/i29/s ... 0_0139.jpg
http://i68.photobucket.com/albums/i29/s ... 0_0887.jpg
Hi,
I was reading as a guest, many times, your sonata posts, cause the same motor.
Now, that i am LPG, i see many LPGs here also.
I was missing some months, as i had to fix the problem car.
I made an account here, to be able get more info, and if i can help with my knowledge also.
I was very, very disappointed after all the problems i got at once i came it's 3rd owner.
feeding problem
http://i68.photobucket.com/albums/i29/s ... 0_0336.jpg
Automatic gearbox problem,
http://i68.photobucket.com/albums/i29/s ... 0_0324.jpg
http://i68.photobucket.com/albums/i29/s ... 0_0286.jpg
http://i68.photobucket.com/albums/i29/s ... 0_0546.jpg
Crank position sensor
http://i68.photobucket.com/albums/i29/s ... 0_0383.jpg
Catalyst blockage, removed with a temp pipe for a week, all metals inside removed, reinstalled
http://i68.photobucket.com/albums/i29/s ... 0_0572.jpg
front tranmission mount needs exchange
http://i68.photobucket.com/albums/i29/s ... 0_0559.jpg
http://i68.photobucket.com/albums/i29/s ... /mount.jpg
and crankshaft pulley separate problem were finally the cause of all my problems.
http://i68.photobucket.com/albums/i29/s ... 0_0354.jpg
After i fixed these things i can say after 4 years driving this car a lot, from 124.000km till today 163.000 km , that it seems to be problem free now.
I had lost my will for this Santamo, and i thought it was a bad construction of a good mitsubishi design.
The problem was that no one ever knew how to service right these cars.
no one put the special transmission oil and the special procedure for renewing timing-belt.
Now, i cross my fingers, i sold all my other cars, except toyota supra, and i use it a lot all day-night.
no problem.
Fuel consumption for 1997cc and car is not bad.
i get normal, easy driving, till 120 km / h no more, no more singing with gas pedal and i get 10 lt/100km consumption.
it's here takes me 450 km.
I never dare to press motor, as it's a very-very heavy car.
i still admire it's way of passing bad above-surface, and the good noise insulation.
The auto nevers gets more than 3000-3500 rpm, it wrks perfect now.
Finally, i hope it will keep working as a japanese car, as it should be.
The small dieseling noise is there at idle, which i think most of you have this noise.
I had uploaded some videos, to specify the noise, was damper pulley seperation.
http://www.youtube.com/watch?v=I80hgqiS14I
http://www.youtube.com/watch?v=X6P2GSTb-u4
So, really at 1500-3000rpm, the engine seems sluggish but no problem for me, just a transportation A to B car with no noise, good structure, good drive, good brakes, low (inside) noise.
On the end, i have to write this.
The mitsubishi space wagon of 1994 had a dashboard made of soft rubber-plastic material.
Santamo dashboards are 100% plastic, so all looks good from inside plastics way, but when you touch them, they have hard-touch. Door panels, real panels, everything is from cheap-cheap plastic.
what a pitty.
mitsubishi materials inside are 100% and i am sure, road noise is lower, when all internal materials are made of soft rubber-plastic material, i think also this caller ABS plastic.
Hyundai accent, of 1995 have this cheap quality of interior also.
bad point for a good chassis construction in my opinion.
But Santamo, has more strong coils, front -rear, than spacewagon.
i have searched all info about our motors. It's the G4CP-dohc with 102kW Which is a hyundai 90% copy of mitsu 4G63. Some parts are different, like oil pump front case and etc.
it's the 1st 16valve DOHC engine, designed for high output Which where, no low torque.
day now, 16valve motors are designed with very narrow and cams are made for getting full of low end torque.
Also it's a 6-Bolt motor, with no crankshaft pulley CPS. It has the combined CPS-CKP Crankshaft and Camshaft positions sensors in 1 device, on the head.
7-bolt motors have 2 sensors, 1 up 1 down.
Anyway , I am happy with it. I did it LPG nd everything works fine.
before LPG
http://i68.photobucket.com/albums/i29/s ... 0_2354.jpg
http://i68.photobucket.com/albums/i29/s ... 2363-1.jpg
after LPG
http://i68.photobucket.com/albums/i29/s ... 0_3221.jpg
http://i68.photobucket.com/albums/i29/s ... 0_3223.jpg
I am very careful with service history, I change oil at 12.000km full synth Castrol GTX magnatec 10W40. Also air filter every 10000 km, cause LPG needs very clean filter.
And spark plugs NGK original BCPR6ES-11, every 10000 km, as again LPG needs more current to produce ignition.
Thats a bit of my car story.
Hi,
feeding problem
no problem.
what a pitty.
before LPG
after LPG
