Rear rotors are ventilated like the front rotors.
1998 - 2000
savvaske35
Příspěvek od savvaske35 »
today, i needed to adjust the hand brake lever.
Release hand brake, not up
1st. 2 rear wheels removed, and removed 15mm diameter rubber caps on the discs.
http://i1188.photobucket.com/albums/z40 ... 0009-1.jpg
If you rotate disc to position this 15mm hole , at 6 o'clock, you can put inside a screwdriver
http://i1188.photobucket.com/albums/z40 ... 0010-1.jpg
and adjust the hand brake lever. I'ts a click-click-click inside round, you move
with the screwdriver up or down TILL YOU CAN NOT ROTATE BY DISC
HAND.
Then you do 5 clicks backwards.
You do this to the other wheel also.
You are finished.
Rear hand brake is with cables and it's a small drum inside rear discs.
Very nice system
So, our rear disc are Ventilated like the fronts.
Does your sonatas Y-1 Y-2 Y-3 has anyone rear disc brakes like Santamo?
Also the front brake-pads aren't like TECDOC says.
They are exactly like 1998 coupe 1.6.
http://i1188.photobucket.com/albums/z40 ... 800008.jpg
by the way, my 1984 celicasupra has both discs ventilated.
http://i68.photobucket.com/albums/i29/s ... 0_3147.jpg
Celicasupra rear
http://i68.photobucket.com/albums/i29/s ... ure011.jpg
Celicasupra front
http://i68.photobucket.com/albums/i29/s ... ure008.jpg
Hyundai Santamo 2.0 G4CP-DOHC 102 kw TAMONA TGstream LPG
Zpět na „SANTAMO“
TOPlist
