Zvysenie vykonu motora - BAC coil
Ak si niekto chce zvysit o nieco vykon motora, pripadne znizit spotrebu, mam tu lacnu moznost - BAC coil (pozrite na internete). Jedna sa o cievky navinute na palivovych hadickach do motora. Skusal som to na benzinovom motore, aj na dizlovom, na oboch to funguje. Motor je tichsi a zbiera sa uz skoro od volnobehu. Je to ako taky maly ciptuning, ale skoro zadarmo.
Pouzite droty su drot plocha 1mm2, ja som pouzil tvrdy drot, ale pouzivaju sa aj lankove dvojlinky 1mm2 pre reproduktory. Navijaju sa 2 bifilarne cievky (bililarna=2 droty vedla seba), ktore sa potom prepoja medzi sebou, vid obrazok. Spojit sa daju omotanim drotov a zaizolovanim izolacnou paskou, alebo mozte pouzit aj svorkovnicu, pripadne zaletovat.
Na benzin sa pouzivaju 2 bifilarne cievky po 13 zavitov (=1 cievka ma 26 zavitov vedla seba), na dizel sa pouzivaju 1 bifilarna 13-zavitova a druha 7-zavitova, na LPG sa pouzivaju 13 a 28 zavitova. Foto je z dizla. Da sa to pouzit aj na upravu vody.
Vyber z originalu:
The Italian B.A.C. Coil.
The claims made for this coil are quite remarkable and as the coil is so very simple that they are easily
checked. The number of turns in the coil is a critical factor, depending on the application. The coil is wound
using two wires of 1 mm. diameter copper wire and connected together as shown in the illustration. The coil
is said to improve the quality of a wide range of things:
1. Water quality can be improved very substantially as follows:
a. Water with mild limestone hardness can be improved with one 15-turn coil on the water pipe.
b. Water with severe limestone hardness can be improved with one 13-turn coil.
c. For industrial use in a severe hardness area: two separate 13-turn coils on the water pipe.
Water treated with any of these procedures makes much healthier drinking water
2. Fuel treatment results in improved mpg results:
a. Petrol: two separate 13-turn coils on the fuel pipe.
b. Diesel: one 13-turn coil plus one 7-turn coil on the fuel pipe.
c. LPG: one 13-turn coil plus one 28-turn coil on the fuel pipe.
Up to 25% fuel reduction can be expected.
3. Natural gas:
a. one 13-turn coil on the gas pipe OR one 28-turn coil if the 13-turn coil is not effective.
Up to 25% gas reduction can be expected.
4. On High-voltage cables such as spark-plug leads:
a. One 13-turn coil on the high-voltage lead.
A further 15% mpg improvement may result from improved fuel burn.
Vyber z originalu:
3. Natural gas:
- 20190501_151102s.jpg (222.29 KiB) Zobrazeno 6272 x
- BAC.jpg (9.56 KiB) Zobrazeno 6272 x
Re: Zvysenie vykonu motora - BAC coil
Ak to naozaj funguje, preco sa to bezne nemontuje, nepouziva ?
Ved vývojári áut pouziju aj kazdu blbost, len aby znizili spotrebu, emisie, zvysili vykon atd.. Nieked boli v móde magnety a ine výmysli, na ktoré mnohí naleteli, vychvalovali ,a po case uznali, ze je to nezmysel..
Accent 1.5CRDi,81kW ,2007
Fabia sedan 1.4
Megane classic 1.9dTi
Punto 1.1,Passat 1.8,Uno 1.3D
Fabia sedan 1.4
Neviem, preco sa to nepouziva. Mozno preto, ze dnesna oficialna fyzika vsetko neovlada. Ja to sem davam po osobnej dobrej skusenosti. Kto chce, moze si vyskusat sam. Material stoji okolo eura, max dvoch, ak tam date svorkovnice. Za tu cenu ta trocha namahy s omotavanim stoji.
Je to super, akorát to nefunguje.
Uz si to skusal? Skusane to bolo na Hyundai I30 1,4 benzin 80kw, Hyundai I20 1,25 62kW, Opel Astra 1,7 CDTI 96kw. Vsade sa zmena prejavila.
Durino,nevíš proč se to nepoužívá? No protože je to pěkná p...vina,která nemůže fungovat nikdy.To si můžeš omotat ty hadičky hadrem a tvrdit,že to funguje.Vlastně ono to funguje na všech autech,ale nemá to žádný vliv na výkon a spotřebu!! Tak tady vidím dalšího " Coppera 5252"!
placebo efekt
Fabia sedan 1.4
Fabia sedan 1.4
Najlepsie sa odsudi este predtym, ako niekto nieco skusi. Netvrdim, ze to zvysi vykon motora o 25%, ale je tam citit zlepsenie, tym padom sa menej stupa na plyn a z toho plynie uspora paliva. Pri cene materialu to stoji minimalne za vyskusanie. Ved za 2 Eura nemate ani 2 litre paliva. Stoji to akurat trocha casu - zhananie materialu a praca. Pomoze to hlavne ludom, co maju slabe motory a kazde, co i len mierne zvysenie vykonu uvitaju. Na tom dizli bolo pred upravou na palubnom pocitaci 5,4l/100km, teraz tam je 4,9l/100km, na benzine 1,25 bolo predtym pri kratkych jazdach 6,8, teraz je tam 6,3. Ja som dal len moznost, kto chce, nech si vyskusa. Nemam z toho ziadny zisk - iba ak dobry pocit, ak to niekomu pomoze.
Uvádíš pouze snížení spotřeby.To dokážu taky,pouze s lehčí nohou na plynovém pedálu a bez červenomodrých drátků!
Uviedol som aj toto:
kristova noha !! to snad nemyslite vazne? kde si mozem objednat rovno 7 kusov?
No u Durina,kde jinde?
Nie objednat, musite si to namotat sami. Ja som dal len navod. Je to sila, ked niekto zadarmo poskytne navod na technologiu, co moze pomoct ludom, ale nikto to nechce, alebo tomu neveri.
Asi ste lenivi nieco pre to aj urobit. Keby mi to nefungovalo, tak by som sa tu predsa nestrapnoval pred vsetkymi. Treba si to jednoducho vyskusat. Ale na ludi plati asi len to, ze musia vsade a za vsetko platit... Smutne...
- Richard555
Protéká tou cívkou nějaký proud ? Je k něčemu připojená, nebo jde jen o vzájemně spojené dráty? Pokud tak, neumím si představit nějaký přínos
